Problem with recording prompt
Nov 6th, 2009
I have a script for recording a prompt (that was working before) and today when I tried to record a prompt I got a prompt of 1KB.
I have IPCC 3.5(3). That kind of script is working on some higher versions of IPCC.
Also I tried to make a script from the beginning but nothing help.
Do you have any idea what could be the problem?
I would appreciate any help ASAP.
Thank you.
BR,
Jelena
duncan.moutrie Wed, 01/27/2010 - 04:20
Hello Jelena,
I have exactly the same problem. Did you ever find a solution?
Duncan
jardalic1 Wed, 01/27/2010 - 04:37
Hello Duncan,
At the end everything worked after restart of the IPCC. I hope this will help you.
BR,
Jelena
