paolo bevilacqua Fri, 11/06/2009 - 06:47
  • Hall of Fame,
    Founding Member
No, unless you write an application for that.
webstd.design Fri, 11/06/2009 - 10:33
Does cisco offer some kind of applications? Where I can find them?
paolo bevilacqua Fri, 11/06/2009 - 10:36
  • Hall of Fame,
    Founding Member
Cisco does not make this application. I'm not aware of anybody that does.
Jaime Valencia Fri, 11/06/2009 - 11:13
  • Cisco Employee,
  • Hall of Fame,
    2011
If the "other phone" is a Cisco IP Phone CUPS has IP Phone Messenger (IPPM) feature for this
There's plenty of info on CCO about the feature if you're interested, otherwise as Paolo mentioned it would require a 3rd party depending on who the "other phone" is.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
