11-06-2009 06:55 AM - edited 03-18-2019 11:57 PM
We have visual voicemail running and appears to be working just fine, except when trying to forward messages to another unity mail box. But if you switch back to audio voicemail it works fine. Any ideas.
11-06-2009 07:45 AM
In order to help we need more info here. You say you forward a message and that seems to be when things don't work. How to they NOT work? What is the difference in how each behaves?
Tray
11-06-2009 07:50 AM
It is in visual voicemail that you can not forward a message, but the same message can be forwarded if you go into audio voicemail. You get the message that is something link voicemail server is down try again later. But you can still listen and delete while in visual voicemail just not forward the message
11-06-2009 09:01 AM
I have no problems doing this in my lab setup. I can't recreate the failure. Please open a tac case on this. It might even be a permissions issue. The user you are sending from should have UnityMsgStoreSvc account Send As permissions on it in Active Directory. Make sure this exists. I imagine it does if you can do it from regular voicemail though so a TAC case would be good at this point.
Tray
11-06-2009 09:05 AM
Thank you for your help. I will check my settings.
