VPN Client
Nov 6th, 2009
I would like to download VPN Clien 5.0.06 however the download page will not let me. As a registered partner reseller I'm told I should have access to the download.
Can any offer any help?
Thanks a bunch
Glenn Quesenberry Fri, 11/06/2009 - 12:32
As a registered Parnter you should have access to the software downloads with your CCO credentials.  It may be that your CCO ID is not correctly configured to do so.  I would recommend you contact the Partner Relationship Team (PRT).  They can help you to resolve all issues with your online account access and configuration issues.
Best Regards,
