ASA SSM-20 is not working as expected
Nov 6th, 2009
Dear Forum,
we have an ASA 5510 with an IPS Module SSM20. When i penetrate the ASA with NMAP from the outside interface i can detect the OS of the servers in the DMZ.
When i allow the ip address of my testing machine on the outside interface the IPS is logging some TCP SYN PORT SWEEPS but not the NMAPFingerprint Event.
Thanks for your advises
bnidacoc Tue, 11/10/2009 - 10:53
It is my understanding that the IPS modules analyze packets permitted to traverse through the host ASA. If your ASA ACL only allows TCP 80 and 443, then it might not look like a sweep to the IPS module's rule. The SSM IPS does not see that which is stopped by the ASA.
Now, if you built a server, placed it in a new/separate (no access from outside) DMZ and permitted an inside host ip any any and then ran a sweep, see if it fires then.
