Configure SSLVPN on ASA5520
Answered Question
Nov 6th, 2009
I have a 5520 Version 6, need to configure sslvpn on it, but I cannot find any instructions for version 6. Everything is version 5 or older.
Is there anything out there for this version?
Correct Answer by JORGE RODRIGUEZ about 7 years 4 months ago
You can use the same examples under 5.x for version 6.x, go to this link under ssl vpn/web section, thats all there is .
SSL VPN/Web VPN
http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.html
Overall Rating: 5 (1 ratings)
rbill1967 Mon, 11/09/2009 - 06:07
I did try the material under 5 but still not very helpful. I need a step by step on the version I am working on or you get kind of thrown off from setting it up.
