What's Wrong Here? AP 1252G
Answered Question
Nov 6th, 2009
Trying to setup up this wireless access point, it's a 1252G. I'm setting it up as a bridge between my wired and wireless network.
The AP is plugged into a port on a 3560 that I've setup as a Trunk port.
I've got the subinterfaces setup on my AP as a part of VLAN 30 and SSID nuaWirelessN.
I have a BVI1 interface and I'm trying to set it up as a management interface, which is why there's an IP address on it, but for some reason I can't ping or access it when I try. Any ideas?
Building configuration...
Current configuration : 1965 bytes
version 12.4
no service pad
service password-encryption
hostname WirelessN
enable secret 5 $1$Xlx.$p9k7g168kCt4I8SQiZS.y0
aaa new-model
aaa authentication login default local
aaa session-id common
ip domain name nua.com
ip ssh version 2
dot11 ssid nuaWirelessN
vlan 30
authentication open
guest-mode
power inline negotiation prestandard source
username cisco password 7 030752180500
username ngarciait password 7 03080B1D5503715A1D
username scurry password 7 110A0C17131D0C5456
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid nuaWirelessN
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0.30
no ip route-cache
bridge-group 30
interface BVI1
ip address 10.1.1.10 255.255.0.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner motd ^C
You Will Be Prosecuted For Unauthorized Access
^C
line con 0
password 7 104D580A0647
line vty 0 4
password 7 020555480856
transport input ssh
end
Correct Answer by jeff.kish about 7 years 8 months ago
Glad it worked! And definitely not wasting my time - I clearly enjoying talking about this stuff for some reason :)
You're right on the money. A trunk is needed only if multiple SSIDs are used. You actually had the AP configured mostly correctly. The main thing that was wrong is that you had no subinterface with bridge-group 1 in use, and this is what links to BVI1.
So let's say you have VLANs 20 and 30 as your data, and management is on VLAN 10. You would:
1. Assign VLANs 20 and 30 to their respective SSIDs
2. Create VLAN 20 and 30 subinterfaces, assigning them to a common bridge-group
3. Create VLAN 10 (native) subinterfaces, assigning them to bridge-group 1
Bridge-groups are tricky to understand. They bridge the Radio and Gig interfaces together, which is easy to grasp without VLANs. However, once you add VLANs, you need a bridge-group for each VLAN. You accomplish this by creating a subinterface for each VLAN on each interface, and you assign each pair to the same bridge-group. Bridge-groups on the physical interfaces (not subinterfaces) no longer do anything, which is again why your management interface couldn't be reached.
The only other thing to understand is that BVI1 links to bridge-group 1, so bridge-group 1 needs to be assigned to the management VLAN. This VLAN doesn't need to be assigned to an SSID, but it does need its own subinterfaces. It's usually the native VLAN, but it doesn't have to be as long as it's on bridge-group 1. (Alternatively, you could create a new BVI for a different bridge-group, such as BVI30 for bridge-group 30, but no one ever does this).
Sorry for talking so much. Let me know if you could use better clarification for some of these concepts. It's good to know for troubleshooting these kinds of things!
Jeff
Okay, so since your management VLAN is the same as your wireless VLAN, this makes things really simple. You don't need trunks, VLANs, or subinterfaces. You'll use a VLAN 30 access port, and you'll build the SSID on the AP without a VLAN designation.
Start with the switch:
switchport mode access
switchport access vlan 30
Now for the AP:
no vlan 30
no int dot0.30
no int gig0.30
Also, since you have the speed/duplex hardcoded on the switch, you should probably do that on the AP as well:
int gig0
speed 1000
duplex full
Perform all these config changes and let me know if that works for you!
Jeff
Thanks Nelson. One more important question - what VLAN is 10.1.1.10 on? And is it really a /16 subnet?
Your problem is that you aren't extending the VLAN to the AP. BVI1 is connected to bridge-group 1, and right now you are only using bridge-group 30. Since you're using subinterfaces, the actual physical dot0 interface doesn't use the bridge-group assigned. You need bridge-group 1 assigned to a subinterface. This should be a quick fix, but it depends on your config.
If the native VLAN is VLAN 30, you'll want to swap all instances of bridge-group 30 to bridge-group 1. You'll also need to mark VLAN 30 as the native on the subinterfaces (encapsulation dot1q 30 native).
If the native VLAN isn't VLAN 30, you'll need to create new subinterfaces for the native VLAN. It doesn't need to be attached to an SSID, but it does need to be part of bridge-group 1.
I hope that helps! If not, please post your switchport config and I'll be able to give a more certain config fix.
Jeff
Overall Rating: 5 (4 ratings)
Correct Answer
jeff.kish Fri, 11/06/2009 - 11:16
  • Silver, 250 points or more
Jeff
nelson.garcia Mon, 11/09/2009 - 12:33
Hey Jeff, here's my switchport config.
switchport mode trunk
speed 1000
duplex full
Correct Answer
jeff.kish Mon, 11/09/2009 - 12:39
nelson.garcia Mon, 11/09/2009 - 13:08
It's on VLAN 30, and yes it's on a /16 subnet.
We use /16 to organize network devices.
Computers on 10.1.0.x
Network Equip. on 10.1.1.x
Servers on 10.1.2.x
Correct Answer
jeff.kish Mon, 11/09/2009 - 13:59
Now for the AP:
no vlan 30
no int dot0.30
no int gig0.30
int gig0
speed 1000
duplex full
Jeff
nelson.garcia Mon, 11/09/2009 - 14:17
Worked Perfectly, Thank You.
A few questions if I may. Sorry if I'm wasting your time.
When would I create a trunk between the access point and the switchport? Would it be when my access point has multiple SSIDs and thus caters to more than one VLAN?
How would the config have changed if the AP was servicing 3 VLANs?
I guess what confuses me is the bridging and trunking. I'm still trying to understand your last post where you talked about my not extending the VLAN to the access point.
Correct Answer
jeff.kish Mon, 11/09/2009 - 14:31
Jeff
maxim_ratinov Tue, 11/10/2009 - 16:29
Hello Jeff,
I see you have experience with APs and I guess you can answer some questions about vlans and bridge on AP1300.
Generally speaking if you read here:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml
Starting from "VLANs on Bridges
Concepts on Bridges" - When you bridge, there is no need to associate a separate SSID with each VLAN!!!
- Can you comment? As I did configuration per this doc using 1 native SSID.
I had bad time trying to understand why I can not reach AP from switch and after
reading your post I think I know why )
In my case native vlan is 1 and is assotiated to bridge group 1, BUT - my management VLAN is 50.
- Should I reconfigure device like:
"interface Dot11Radio0.50
encapsulation dot1Q 50
bridge-group 1(was 50)"
and then for native vlan
"interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 100(was 1)"
jeff.kish Wed, 11/11/2009 - 06:12
Hi maxim,
You're right about the bridges - you only need one SSID to carry all VLANs, and this is because it's a 'trunking' radio connection instead of an access connection. Many people starting out in wireless (myself included) will learn how to configure APs, and when moving to bridges it seems natural that you need an SSID per VLAN. But that doesn't scale well, and when in bridging mode a Cisco AP will send all VLANs across the infrastructure SSID.
Regarding your configurations, they all look correct! Give them a try and let me know what happens. Don't forget to apply the same changes to the Ethernet subinterfaces.
Jeff
maxim_ratinov Thu, 11/12/2009 - 10:59
Hello Jeff.
Thanks for reply - so it makes my life easier as I do not need to configure multiple SSIDs. It seems like I see non-root AP from root bridge. (at least I see BVI1 IP of non-root...but I can not ping it)
I try all possible configs and...failed. Can not ping any ip from AP and AP is not pingable from switch (
What I did:
1) Associated bridge group 100 to native vlan 1(voip vlan in network) and bridge group 1 to management vlan 50 (config attached). Not working
2) Associated BVI1 ip with ip from native vlan range - it is funny but not working as well. (config attached)
3) Connected my notebook with ip from native vlan range - working fine.
4) Triplecheck switch configuration.
Any ideas?
maxim_ratinov Thu, 11/12/2009 - 13:16
I found the issue - ssid was configured for vlan 1, as soon as I did reconfiguration of native vlan from 1 to 50 (which is pretty unusual) and reconfigured radio and ethernet subinterfaces to native vlan 50 - I recieved positive results!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
