CUCM 6.1(2) device unregistered reason code
Answered Question
Nov 6th, 2009
Can anyone tell me what reason code 13 means with reagards to a device unregistering? I suspect that it is network related but can only find reason code 12 on cisco.com.
From app logs:
ccm: 403998: Nov 05 05:01:06.808 UTC : %CCM_CALLMANAGER-CALLMANAGER-3-DeviceUnregistered: Device unregistered. Device name.:SEPxxxxxxxxxxxx
Device IP address.:xxx.xxx.xxx.xxx
Protocol.:SCCP
Device type. [Optional]:436
Device description [Optional].:phone-xxxx
Reason Code [Optional].:13
Cluster ID:StandAloneCluster
Node ID:xxxxxxxxxx
Correct Answer by Jaime Valencia about 7 years 8 months ago
All the codes are found in the error messages docs
System Error Messages for Cisco Unified Communications Manager 7.1(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/err_msgs/7_x/ccmalarms712.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
glenn.martindel... Fri, 11/06/2009 - 11:29
Can soemone help me understand why/when I would get a reason 16 DuplicateRegistration?
Rob Huffman Fri, 11/06/2009 - 13:43
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Glenn,
Here is the explanation;
ReasonCode 16: DuplicateRegistration. This means that Cisco Unified CallManager detected that the same device was registered on two nodes at the same time. When this happens, Cisco Unified CallManager sends a restart request to the phone to force the phone to register with only one Cisco Unified CallManager.
I believe this can happen if a phone loses contact with its Primary CUCM and moves to the Secondary CUCM and registers before the de-registration on the Primary has been fully completed. I'm pretty sure this is a fairly rare network related problem.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/5_1_2/512bcmrn_1.pdf
Hope this helps!
Rob
