Unity Server and AA
Nov 6th, 2009
Hello
Where can i found information of the limitation of Unity Server for configuring Auto-Attendant and other scripts and prompts???
How many scripts and prompts can i upload on the server for making applications??
Thanks in advance for your help.
lindborg Fri, 11/06/2009 - 12:44
Unity doesn't use "Scripts" per se, it uses handlers (call handlers, interview handlers, name lookup handlers) in conjunction with subscriber objects to create audio text applications. A good place to start is this document here:
http://www.ciscounitytools.com/Documents/Unity/AudioTextApplicationsinUnity.doc
little old but still applies to Unity versions shipping today.
There's no practical limit on the number of handlers you can create or the "tree depth" you can go do - I've setup systems with more than 10,000 call handlers on them - way more than any viable audio text application would likely need.
