Aironet 1240AG AP
Nov 6th, 2009
I have a 1240AG that shows a red light at the Ethernet and Radio indicator on bottome of unit. Can not connect to it thru the web and ip address. Any ideas on what to do?
jeff.kish Fri, 11/06/2009 - 13:16
That likely means that it has an IOS error. You'll need to console in and see if it's in ROMMON. If it is, perform the following to fix it:
Configure a TFTP server/PC to use the address 10.0.0.2
Place a 1240 autonomous image in the TFTP root directory
Rename the file "c1240-k9w7-tar.default"
Connect the PC to the AP using a crossover cable (a normal should also work)
Turn the AP off, then power it back on while holding the MODE button
Release the button once the AP LEDs turn red
That should load the IOS image back on for you.
Jeff
Leo Laohoo Sun, 11/08/2009 - 14:05
Jeff's right. It's it's only red light all the time then the AP is on ROMMON.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
