how to config netflow
Answered Question
Nov 6th, 2009
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-IPSERVICESK9-M), Version 12.2(33)SRB5.
how to config netflow,monitor the atm port.
Correct Answer by Giuseppe Larosa about 7 years 6 months ago
Hello Qing,
because
>> NDE on the PFC supports NDE versions 5, 7, and 9 for the statistics captured on the PFC
you should configure the device for using version 5 (or version 7 that is specific of catalyst platform)
the command should be:
config t
ip flow-export version 5
or ip flow-export version 7
but I strongly recommend you to read the following document to be aware of all possible side effects and limitations
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/nde.html#wp1020457
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
paolo bevilacqua Fri, 11/06/2009 - 15:56
  • Hall of Fame,
    Founding Member
Have you tried the searchbox top right corner ?
JORGE RODRIGUEZ Fri, 11/06/2009 - 15:57
  • Green, 3000 points or more
Agree with Paolo.. this is a second search..
Visit this link for general overview of netflow if you indeed trying to do traffic accouting on your router. within the link bellow see link Introduction to Cisco IOS NetFlow - A Technical Overview for configuration overview.
http://www.cisco.com/en/US/products/ps6601/products_ios_protocol_group_home.html
Mohamed Sobair Sat, 11/07/2009 - 02:38
  • Gold, 750 points or more
As Paolo Suggested, you could find an answer quickly an easily using the search tool first.
Also documentation posted should be helpful.
Config of Netflow is straight forward, You have to apply on the Interface you want the traffic flow to be seen, and if you have Netflow Managment station, you could also send Netflow traffic to the Netflow Managment station using special commands.
Mohamed
QFX527518 Sat, 11/07/2009 - 04:09
thanks.
before we use cisco 7507,and use netflow version 5.by the manageEngie netflow tools,can monitor the flow of interface and the apply flow.now,we update to cisco 7606.and under interface ,define ip flow ingress,on the globle define the ip flow-export.define the netflow version is 9.but the netflow tools cant collect the flow,on the netflow tools,we only see some router protocol packet.why?can give me some example about how to config the netflow on cisco 7600 serial router.thx.
Correct Answer
Giuseppe Larosa Sat, 11/07/2009 - 05:42
  • Hall of Fame,
    Founding Member
Hello Qing,
because
config t
Hope to help
Giuseppe
JORGE RODRIGUEZ Sat, 11/07/2009 - 06:14
Quin, this may help as Giuseppe pointed use version 5, this simple scrip bellow runs on mpls edge 3845 routers works great with manage engine
ip flow-export destination 2055
ip flow-top-talkers
top 25
sort-by bytes
interface Serial4/0
ip route-cache flow
QFX527518 Sat, 11/07/2009 - 18:56
thx.on the globle config,add mls nde sender version.netflow analyer can work correctly.
