Outlook Plugin (Office 2003) 'serious problem'
Nov 6th, 2009
Our VP of IT just received this message in his outlook:
Outlook experienced a serious problem with the 'ironport outlook' add-in. If you have seen this message multiple times, you should disable this add-in and check to see if an update is available. Do you want to disable this add-in? (yes) (no)
Anyone see this before? What do you do to fix it?
We plan on rolling this plugin out company wide by December 1st. We cannot have this issue.
