11-07-2009 03:29 AM - edited 03-15-2019 08:23 PM
Please light me how to use + route pattern, when ever I am trying + route pattern, the lady says your call cannot be completed as dial, so my client not able to dial the missed International call directly.
I have check the + route pattern without partiton also.
Please correct me what I am missing in + route pattern.
Solved! Go to Solution.
11-08-2009 10:58 PM
11-07-2009 09:57 AM
use 9.011! route pattern,
you need to uncheck the urgent priority for this particular route pattern,
There is an option in callmanager administration-->Service-->Service
parameters--> lick on advance button and then search for national number
prefix (add 91), international number prefix (add 9011), subscriber number
prefix (add 9), unknown number prefix( add 9)
11-07-2009 08:28 PM
Yes I am using 9.011 pattern to, my question is if I am finding +1408 route pattern as missed call, how to dial that missed call pattern without edit that missed call number, when I am trying + route pattern, I am getting a lady voice your call cannot be completed....
Please light me on + route pattern
11-08-2009 04:19 PM
Hi there,
a route pattern \+! that has a called party transformation to strip the + and apply the external access and applicable international access code should do it.
regards,
Paul
11-08-2009 10:51 PM
Did you try this,
you need to uncheck the urgent priority for that route pattern,
11-08-2009 10:58 PM
also, one more update
CIPC 7.O E.164 "+" is NOT supported
11-11-2009 02:42 AM
the natinal, international and subscriber in Service parameter coming with options phone, MGCP gateway and H.323 gateway, should I update the calling number prefix in all the steps, please light me about the prefix number.
