Permit ALL
Answered Question
Nov 7th, 2009
Hi!
How to permit ALL on my PIX501 fw?
BR
Correct Answer by Panos Kampanakis about 7 years 3 months ago
You need to open the ACL, only if there is one on the inside high security interface.
If you are pinging from an inside host you will not be able to ping the outside interafec of the ASA, only the inside.
For being able to ping outside hosts check your natting on the firewall. You need to translate the inside host in such a way that the outside host has a route back.
I hope it helps.
PK
Overall Rating: 5 (1 ratings)
hdashnau Sat, 11/07/2009 - 08:18
Details are lacking on this question. To create an ACL that permits all traffic:
access-list myacl permit ip any any
-heather
MUXAHMUXAH2 Sat, 11/07/2009 - 13:03
I am asking because I cannot ping my outside interface and any other outside ip.
Correct Answer
Panos Kampanakis Mon, 11/09/2009 - 07:06
I hope it helps.
PK
