Issue about IPV6 Stateless auto-config
Nov 7th, 2009
I have this link local adress:
FE80::A1:2345:6789
and this router global adress:
2001:AAAA:BBBB:CCCC:DDDD::1/64
What is the statless autoconf global unicast address of my station?
2001:AAAA:BBBB:CCCC::A1:2345:6789
or
2001:AAAA:BBBB:CCCC:FE80::A1:2345:6789
Overall Rating: 3 (2 ratings)
Nagendra Kumar ... Sun, 11/08/2009 - 06:36
  • Cisco Employee,
The RA (Router Advertisement) message sent by IPv6 router will have the prefix which you mention using "ipv6 nd prefix-advertisement" command with autoconfig bit set. This prefix normally will be the global unicast prefix.
In your case, if the RA sends 2001:AAAA:BBBB:CCCC/64 prefix, the receiving node will concatenate its interface identifier and make it a 128 but address and assign the same to the interface.
For example, if the MAC address of your interface is XXXX.YYYY.ZZZZ, the interface identifier will be XXXX.YYFF.FEYY.ZZZZ and the ipv6 address will be 2001:AAAA:BBBB:CCCC:XXXX.YYFF.FEYY.ZZZZ
HTH,
Nagendra
qudatheocelbatran Sun, 11/08/2009 - 20:08
Your recommended choice is not available in my test/quizz. Thanks anyway.
Any other opinions pls ?
Giuseppe Larosa Mon, 11/09/2009 - 04:04
  • Hall of Fame,
    Founding Member
Hello Theodor,
the answer that has been provided to you by Nagendra is the correct one.
You should take in consideration the fact that your test/quiz can be wrong.
Note also that providing a rating of 1 in these forums is regarded as unfair and in this case it is.
read by yourself ipv6 basic addressing guide about stateless autoconfiguration
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-addrg_bsc_con.html#wp1038169
it is IPV6 prefix /64 + EUI associated to device NIC mac address
EUI is a 64 bits entity derived from MAC address
Hope to help
Giuseppe
