11-07-2009 06:42 AM
What action generates the utm.log_backup file in LMS 3.2 on Windows? Does it happen once daemon services are stopped and restarted?
Solved! Go to Solution.
11-07-2009 09:29 AM
Yes, and it also is regenerated when it reaches its max configured size by the UTManager process.
11-07-2009 09:29 AM
11-08-2009 04:04 AM
What is the max configured size?
11-09-2009 12:23 PM
The default is 1000000 bytes. This is configurable in the NMSROOT/campus/lib/classpath/com/cisco/nm/cm/ut/utm/properties/utm.properties file.
