hardware-address or client-indentifier
Rafael Jimenez
Level 4
Level 4
I read several docs about the dhcp manual bindings. Im not even tried yet but can somebody tell me which is right(hardware-address or client-indentifier) for Cisco IP Phones?.
Thanks.
paolo bevilacqua
client-identifier, ad you have to add like 01 at the end.
Never got to understand what hardware-address does and why doesn't work.
Paul, the 01 is at the end or at the begining of the mac ?.
Paul, I have one of those "nice" user that do not wat vlans in the network. Is a 25 ip phones and 30 pcs, "corportate policy" he said....
I had to convince him to use dhcp for the ip phones.
Im looking for a way to give ip addr to the ip phones only.
Because there is only one vlan I dont want the dhcp lease ips to the pcs, only for ip phones.
Manual bindings may be, but also I need some docs for dhcp class.
Can you give some ideas?.
Thanks.
Too bad, users that think they know everything = big problem. You should really tell that unless phones are in vlan, it will not work.
Anyway I don't think you need class just client-identifier, do show ip dhcp server bindings you will see the correct mac format to use.
