both voice and data vlan does not work on the same port
Nov 7th, 2009
I have a home lab with the following setup:
vlan 5->data
vlan 10->voice
CME Router Cisco 1760 has been configured as a DHCP server to assign IP for both for data and voice vlan.
CME Router1760 configuration:
int f0/0.10
ip address 192.168.10.1
encap trunk dot1q 10
int f0/0.5
ip address 192.168.5.1
encap trunk dot1q 5
Switch3524 configuration
int f0/1
switchport access vlan 5
switchport voice vlan 10
int f0/2
switchport access vlan 10
int f0/24
switchport mode trunk
switchport trunk encap dot1q
switchport trunk allowed vlan 1,5,10
int vlan 1
no ip address
int vlan 5
ip address 192.168.5.4 255.255.255.0
I get request time out when I ping 192.168.5.4
IP phone works in VLAN 10 when I plug it to f0/2.
Computer gets IP address from data Vlan when I plug into f0/1.
My question is how can I make both data and vocie vlan work at the same port.I also tried with setting the trunk port in f0/1 but it does not work.
I will appreciate any thoughts....
Thanks in advance.
Overall Rating: 4 (1 ratings)
david-lima Sun, 11/08/2009 - 14:05
  • Bronze, 100 points or more
Hi friend, as a suggest, I have this configuration in all my switches and it work good:
interface FastEthernet0/1
switchport access vlan 460
switchport mode access
switchport voice vlan 461
mls qos trust dscp
spanning-tree portfast
Also make sure that the voice vlan is UP (show interface vlan X)
hth
David
Paul Reck Sun, 11/08/2009 - 15:11
  • Silver, 250 points or more
Hi Arjun,
if you're going to use this method in your lab try configuring f0/1 like this
int f0/1
switchport trunk native vlan 5
that should get you up and running,
regards,
Paul
