11-08-2009 07:12 AM - edited 03-06-2019 08:30 AM
hello
is it possible to connect a router with another router using the fastethernet ports ?
thanks
Solved! Go to Solution.
11-08-2009 07:20 AM
Yes, you can connect routers directly using FE ports. You need to use cross cable if the platform doesnt support auto-MDIX feature.
HTH,
Nagendra
11-08-2009 07:20 AM
HTH,
Nagendra
11-09-2009 07:06 AM
Yes ofcourse u can connect!
Sohail Akhtar
sohailpk.blogspot.com
