encrypting a vlan on a trunk
Nov 8th, 2009
We have a dark fibre connection between out two buildings. We are carrying some vlans from main site to remote site. One of these Vlans is critical and our security guy wants us to encrypt this vlan.
How can i achieve this goal? Can i use Gre for tunneling and then encrypt it? or any other idea?
Collin Clark Mon, 11/09/2009 - 09:35
  • Purple, 4500 points or more
Is the link between the sites layer 2? If so you'll need to encrypt between the end devices (ie the servers). If it's a layer 3 connection, then yes GRE and IPSec will work just fine.
