Cisco Publisher Crash
Nov 8th, 2009
Hi Engineers,
Anybody can give a step by step document on how to restore my CCM publisher,
I got an error before booting up the server
Windows 2000 could not start because the following file is missing or
\WINNT\SYSTEM32\CONFIG\SYSTEMced startup options for Windows 2000, press
You can attempt to repair this file by starting Windows 2000 Setup using
the original Setup floppy disk or CD-ROM Select 'r' at the first screen
to start repair.
There is a document called a "SAME SERVER RECOVERY" but it did not tells you what to do from the start to the finished.
Can anybody help, Please..
Thank you very much,
virverma Sun, 11/08/2009 - 23:02
this error message is an existing defect,
This defect happens on all the servers running MCS OS versions 2000.2.6 SR 2 and below.
Any servers that have 2000.2.6 SR3 and above installed or 2000.2.7 and above installed
will not see this problem.
Try this workaround,
Delete these registry keys:
Add these registry values:
Server\WinStations\RDP-Tcp\fDisableCpm = 1
Server\WinStations\RDP-Tcp\fDisableLPT = 1
lesterccna Mon, 11/09/2009 - 00:49
Hi Virverma,
Thanks to your reply,
I couldn't bootup to the windows 2000 server OS, it stuck-up and hang-up in the black screen, please refer to my attachment.
How can i fix this and return to Operational OS.
Thank you very much
