Network drop down
Nov 8th, 2009
hi
i just change my router to a cisco 871 and it appear that my connection keep droping out every two days i lost all connection. i have to reboot the router then everything work fine again. Can somebody help me out there
paolo bevilacqua Sun, 11/08/2009 - 20:35
  • Hall of Fame,
    Founding Member
Likely IOS bug, try to get access to a newer version.
deelant04 Mon, 11/09/2009 - 18:59
hi
am a bit new on cisco can you please help me how to get the new IOS version and how to upload it onto the router
spremkumar Sun, 11/08/2009 - 22:00
  • Red, 2250 points or more
Which connection you are mentioning over here? Are you pointing out WAN or LAN or Wireless ?
regds
Joseph W. Doherty Tue, 11/10/2009 - 05:29
Assuming you have a default route statement, does it point to the interface or to the next hop's IP address? If the former, try the latter.
