The Cisco 7609 can't display the running-configuration
Nov 9th, 2009
I haver Cisco 7609 with sup720. Today, I find it can't display the running-configuration, when I execute the "show run" command ,it stop there about 10 minutes,and responds with "Unable to get configuration. Try again later."
Any help?
Thanks.
------- show running-config ----------
------------------ show version ------------------
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-IPSERVICES-M), Version 12.2(33)SRB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 10-Oct-07 13:47 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
ZBFJ-HX-CISCO7609 uptime is 2 weeks, 5 days, 22 hours, 59 minutes
Uptime for this control processor is 2 weeks, 5 days, 23 hours, 3 minutes
Time since ZBFJ-HX-CISCO7609 switched to active is 2 weeks, 5 days, 23 hours, 2 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 13:14:32 beijing Tue Oct 20 2009
System image file is "bootdisk:c7600s72033-ipservices-mz.122-33.SRB2.bin"
Last reload type: Normal Reload
cisco CISCO7609 (R7000) processor (revision 1.2) with 458720K/65536K bytes of memory.
Processor board ID FOX1222G3Z7
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
45 Virtual Ethernet interfaces
100 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Giuseppe Larosa Mon, 11/09/2009 - 03:53
Hello Xiaojun,
this can be related to a SW bug.
I remember other threads about this.
can you enter config mode?
I would consider upgrading IOS image
to 12.2(33)SRD2
Hope to help
Giuseppe
