MGCP: ISDN L3 will not establish
Hi.
I have two 3640 routers with E1 modules installed, a back to back ISDN cable and can get ISDN L3 up and running OK.
when I change over to using MGCP I cannot get isdn L3 (multiple frames established) in show isdn status.
Below is the working output, then the MGCP non working output.
Thanks for any advice.
John
RTR_E_PSTN#show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial2/0:15 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80FF7FFF
Number of L2 Discards = 0, L2 Session ID = 81
Total Allocated ISDN CCBs = 0
isdn switch-type primary-net5
controller E1 2/0
clock source internal
pri-group timeslots 1-24
interface Serial2/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice data
no cdp enable
RTR_A#show isdn status
ISDN Serial3/0:15 interface
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Number of L2 Discards = 0, L2 Session ID = 72
controller E1 3/0
interface Serial3/0:15
no ip address
encapsulation hdlc
no cdp enable
now use MCGP
ccm-manager config server 10.100.9.11
ccm-manager config
controller E1 3/0
pri-group timeslots 1-24 service mgcp
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
RTR_A#show ccm-manager
MGCP Domain Name: RTR_A
Priority Status Host
Primary Domain Name Unresolvable Pub1
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 09:40:43 GMT Nov 9 2009 (elapsed time: 01:01:37)
Last MGCP traffic time: 10:36:39 GMT Nov 9 2009 (elapsed time: 00:05:41)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul/Redundant link is down
Configuration Auto-Download Information
Current version-id: 1257434168-47c77570-bea6-48ac-bdc7-ffcee28bf3fc
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
Configuration Error History:
voice-port 3/0:15
echo-cancel coverage 8
controller E1 3/0
no pri-group timeslots 1-31
FAX mode: cisco
Brandon Buffin Mon, 11/09/2009 - 06:44
  • Purple, 4500 points or more
Your gateway is unable to contact and register with the Callmanager for some reason. Check connectivity between the gateway and CCM. Can you ping? Also, make sure the CCM configuration is correct for the gateway. Check the name - it should match the hostname on the gateway. Make sure it is configured for the correct type of interface.
Hope this helps.
Brandon
