Client Configuration
Nov 9th, 2009
i have two controllers 4402and 15 WAP 1250s with both radio AGN
i need to configure the client to support maximum Speed
please advice what is the best Practice configuration for Both WLC and client
(the maximum speed for 2.4Ghz GN-radio)
the Laptop and driver Detail
DELL wireless 1510 wireless-N WLAN
Driver Provider :Broadcom
Driver Date :3/21/2008
dancampb Mon, 11/09/2009 - 07:57
Make sure you use either WPA2/AES or an open WLAN and have WMM enabled. Getting the full possible 300Mbps data rates are not going to be advisable on the 2.4GHz range because this requires channel bonding. Setting up channel bonding on the 2.4GHz radios will cause co-channel interference between every AP as they all will be using channel 6.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
