Devices not supported in RME ????
Nov 9th, 2009
We have two cisco 7201 with the following characteristics:
Cisco 7201 (c7201) processor (revision B) with 917504K/65536K bytes of memory.
Processor board ID 78002382
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
1 slot midplane, Version 2.0
The problem is that these devices seem to be supported in RME 4.1.1, but I am not able to view their logs, get their configuration or anything else related to RME. The configuration is no different from any other router that is fully supported by CW.
What might be the problem?
Thank you in advance,
Katerina
MICHEL.HEGERAAT Mon, 11/09/2009 - 03:58
Is in RME device list in the "normal" state?
Does it show up in the CDA report?
Cheers,
Michel
katerina.dardoufa Fri, 11/13/2009 - 02:53
Hi, everything seems to be ok now. I deleted and re-added the devices.
Thnx for your assistance
