6503 Routing Module cpu spike(False alert? )
Nov 9th, 2009
Two machines shared bulk of data across my cisco 6503 Core switch.
Its routing module CPU reach 99%, switching module remained 20% normal.
When i do sho proc cpu sorted, adding each CPU utilization is not equal to 99% , is it false alert?
If true what can be reason for that? cant 6500 support high data transfer?
attached is output of show proc cpu sorted
Giuseppe Larosa Mon, 11/09/2009 - 08:02
  • Hall of Fame,
    Founding Member
Hello Muhammad,
you need to consider also cpu usage by interrupts that should take in account the difference
>> CPU utilization for five seconds: 99%/83%; one minute: 96%; five minutes: 86%
you see the 99%/83% the sum of all processes should reach second value
see
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml#high_cpu
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml#causes
Hope to help
Giuseppe
