ACL
saquib.tandel
sh access-list 99
10 permit 192.168.1.0, wildcard bits 0.0.0.255 (31 matches)
20 permit 192.168.9.0, wildcard bits 0.0.0.255
30 permit 172.17.1.0, wildcard bits 0.0.0.255 (29 matches)
40 permit 172.17.3.0, wildcard bits 0.0.0.255 (41 matches)
50 permit 192.168.6.0, wildcard bits 0.0.0.255 (29 matches)
60 deny any (150 matches)
How can I add another line before deny statement without removing access-list 99 and applying again
8 Replies 8
burleyman
Level 8
Level 8
Like this...
55 permit......
Mike
access-list 99 permit 192.168.1.0 0.0.0.255
access-list 99 permit 192.168.9.0 0.0.0.255
access-list 99 permit 172.17.1.0 0.0.0.255
access-list 99 permit 172.17.3.0 0.0.0.255
access-list 99 permit 192.168.6.0 0.0.0.255
access-list 99 deny any
My question was how to add another line before deny statement in one step
Sorry totally misread the question. Having one of those days.
I am not 100% sure how after looking at it.
I will defer to others who have much more knowledge than I.
Mike
you can't, only with named access-lists can you insert ace's.
I just tried on one of our test switches and srue is absolutely correct.
And sorry for my errant post earlier.
Mike
Hello all.
It is possible to add new lines to numbered ACLs in later releases of code. The output below was on a router running 12.4(21)
R1#config t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#access-list 99 permit 192.168.1.0 0.0.0.255
R1(config)#access-list 99 permit 192.168.9.0 0.0.0.255
R1(config)#access-list 99 permit 172.17.1.0 0.0.0.255
R1(config)#access-list 99 permit 172.17.3.0 0.0.0.255
R1(config)#access-list 99 permit 192.168.6.0 0.0.0.255
R1(config)#access-list 99 deny any
R1(config)#do show access-list 99
Standard IP access list 99
60 deny any
R1(config)#ip access-list standard 99
R1(config-std-nacl)#55 permit 192.168.11.0 0.0.0.255
R1(config-std-nacl)#do show access-list
55 permit 192.168.11.0, wildcard bits 0.0.0.255
60 deny any
Simon
that's a named access-list..it just so happens you named it '99'.
Hello Srue.
No it isn't. If you look at how I configured it I used 'access-list 99' and not 'ip access-list standard 99'
You can try it yourself if you still need convincing. Also a simple google search shows pages which back up my configuration
http://blog.internetworkexpert.com/2008/01/03/editing-numbered-access-lists-on-the-fly/
Simon
