CME to CME integration
Answered Question
Nov 9th, 2009
hello folks
do you know or could you share a document that will explain cme to cme integration ?
thank you
Correct Answer by Kenneth Mohammed about 7 years 3 months ago
Basically, you would just have dial-peers on each cme pointing to the remote site:
example:
California router
dial-peer voice 100 voip
description **Calls to Indianapolis**
destination-pattern ....(extensions in Indy)
session target ipv4:x.x.x.x (IP of Indy router)
dtmf-relay h245-alphanumeric
Indy router
description **Calls to California**
destination-pattern ....(extensions in Cali)
session target ipv4:x.x.x.x (IP of Cali router)
Hope that helped, if so please rate.
Overall Rating: 5 (1 ratings)
Kenneth Mohammed Mon, 11/09/2009 - 08:04
Can you be more specific? Are you just trying to network CME's at 2 different sites? Please explain further.
cris_jimenez Mon, 11/09/2009 - 08:06
yes
I'd like to integrate 2 CME systems in 2 different locations
Indianapolis, California
there's going to be a VPN tunnel between the 2 sites and I'd like to have 4 digit dialing between the 2 sites
the site in indianapolis currently has cme version 4.2, the site in california has cme version 4.1
and i think i may need a GK for BW control, but i'm not sure i haven't found something that will explain how to integrate the 2 systems together
Correct Answer
Kenneth Mohammed Mon, 11/09/2009 - 08:10
example:
California router
Indy router
cris_jimenez Tue, 11/10/2009 - 10:27
hello,
I configured the dial-peers however i can only call the phones from california to indy. if i try to call from indy to california i get fast busy ... what am i doing wrong ?
cris_jimenez Thu, 11/12/2009 - 07:13
I did a debug voice ccapi inout and realize that when i was placing the call it was actually getting to the remote ccme however the incoming dial-peer was wrong i reconfigure it and it fix my issue
