Spanning-Tree Topology Question
Hi There,
Should all switches participating in and trunking the same vlan agree on the time of the last topology change for that vlan.
The switches on my LAN are reporting various values.
4507-01#show span vlan 71 det | in last change
Number of topology changes 26 last change occurred 6w6d ago
4507-02#show span vlan 71 det | in last change
Number of topology changes 37 last change occurred 4w4d ago
N5_1SWL#show span vlan 71 det | in last change
Number of topology changes 13 last change occurred 1y4w ago
I would have thought that a topology change on one switch would have been reported to the root and passed to the other switches from there.
Is the topology change repoted only locally significant to the switch?
Jim
Giuseppe Larosa Mon, 11/09/2009 - 09:01
Hello Jim,
the switches should agree on STP "uptime" on the vlan.
Have you enabled STP features like STP loop guard that could make one switch to ignore some changes?
I've checked in a campus of mine on two devices one is at distribution and one access layer and they match
sh spanning-tree vlan 9 det
VLAN0009 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 0, address 001d.4605.4009
Configured hello time 2, max age 20, forward delay 15
We are the root of the spanning tree
Topology change flag not set, detected flag not set
Number of topology changes 1299 last change occurred 00:57:06 ago
from Port-channel10
VLAN0009 is executing the rstp compatible Spanning Tree protocol
Bridge Identifier has priority 32768, sysid 9, address 0022.90a4.c380
Configured hello time 2, max age 20, forward delay 15, transmit hold-count 6
Current root has priority 0, address 001d.4605.4009
Root port is 257 (TenGigabitEthernet5/1), cost of root path is 2
Number of topology changes 757 last change occurred 00:57:27 ago
Hope to help
Giuseppe
