11-09-2009 08:21 AM - edited 03-11-2019 09:38 AM
output to view failover status gives "not monitored" states on the available interface although all of the interfaces are up & passing traffic. same is the case with other unit.
Please advise how to deal with this.
Thanks!
Solved! Go to Solution.
11-10-2009 01:17 PM
Sunny,
in your primary asa issue:
monitor-interface Zone1
monitor-interface Zone2
- wait few seconds , then issue "show failover" monitor status on the interfaces should be normal
11-09-2009 12:24 PM
Can you post the actual output of show failover from primary-active fw.
if your firewall logical interfaces have the (no monitored) output by defaul logical interfaces are not monitored thus you will need to issue from the active firewall monitor-interface nameif .
asa(config)#monitor-interface
11-10-2009 03:46 AM
Sh failov with values changed:
Interface Zone1 (10.11.2.3): Normal (Not-Monitored)
Zone2 (10.12.3.4): Normal (Not-Monitored)
There is no problem in passing traffic across these firewalls.
failover
failover lan unit primary
failover preempt 120
failover lan interface Failover Vlan155
failover link Stateful_Link Vlan154
failover interface ip Failover 10.2.155.251 255.255.255.252 standby 10.2.155.250
failover interface ip Stateful_Link 10.2.155.249 255.255.255.252 standby 10.2.155.248
11-10-2009 04:04 AM
In order to enable health monitoring on a specific interface, use the monitor-interface command in global configuration mode: monitor-interface
Even if you are not monitoring an interface, the interface will still pass data traffic!
11-10-2009 01:17 PM
Sunny,
