I can not use the same ip address for three NDGs ACS.!
Answered Question
Nov 9th, 2009
Hello. Install ACS 4.2 Build 124 Patch 13, I created three NDGs, My server has the IP 192.168.1.10, adding the same three NDGs server gives me this error:
An overlapping IP range 192.168.1.10 conflicts have been detected with ACS entry of 192.168.1.10.
besides, if you add a server with an IP that does not exist and then remove it, do not get such option to remove.
suggestions on this?
Correct Answer by Jagdeep Gambhir about 7 years 3 months ago
Make any change in the IP address of that server. Eg lets say IP is 192.168.1.1 , change it to anything like
192.1.1.1 submit and restart.
Go to control panel , admin tools, services...restart csadmin.
Now you should see aption to delete that aaa-server.
~JG
Overall Rating: 5 (3 ratings)
Jagdeep Gambhir Mon, 11/09/2009 - 12:03
Hi Kevin,
There is no need to add server is all NDG's. You can place server in any NDG, that server will take care of all aaa-clients.
~JG
Do rate helpful posts
Kevin Morales Mon, 11/09/2009 - 12:32
thank for reply, i try the delete AAA Server but not show the option delte!..what can i do?
Jatin Katyal Mon, 11/09/2009 - 12:39
Hi Kevin,
Please change the ip of the server to any random ip like 1.1.1.1 and submit the cahnges. After that go to start > run > services.msc and restart the Csadmin services. This would required re-login to ACS GUI.
Go to the same server > edit the changes and you would see delete + apply option.
NOTE: The above steps are only applicable for ACS windows.
JK
Plz rate helpful posts-
Correct Answer
Jagdeep Gambhir Mon, 11/09/2009 - 12:39
~JG
