LAP1131 to autonomous mode
Nov 9th, 2009
I am trying to follow the directions from here (the TFTP method): http://cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c4.html#wp1091047
However, when I restart the AP with the mode button held down, it never connects to the TFTP server. I hold the mode button until the R light is solid red, as described in the document. The TFTP server (solarwinds) is set to IP 10.0.0.2 (I've also tried 10.0.0.10 without effect). I've tried both directly connecting the AP to the laptop via Cat5 and using a switch between them.
At no point does the TFTP server register a connection and the activity monitor for the Local Area Connection Status on the laptop shows 0 received packets. Eventually the AP shows the E light as green with occasional flashes off and the R light is flashing red in a 1 flash-pause-2 flash-pause pattern.
Any suggestions for getting this LAP into autonomous mode would be greatly appreciated.
Thanks.
Overall Rating: 4.5 (2 ratings)
mscherting Mon, 11/09/2009 - 11:02
I normally do this with a crossover between a laptop running tftp (3CDaemon)and the AP. I also have a console session open to the AP from the laptop and I don't use POE for this.
Leo Laohoo Mon, 11/09/2009 - 13:51
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you connect the LAP to the WLC and let it join?
jordan01060 Tue, 11/10/2009 - 04:33
Thank you for the replies.
-I tried a crossover cable instead of the straight-through Cat5. There was no change in behavior.
-Unfortunately, I don't have a WLC, which is why I'm trying to get the LAP reflashed as an autonomous AP.
Robert.N.Barrett_2 Tue, 11/10/2009 - 04:44
  • Bronze, 100 points or more
- Make sure your subnet mask is 255.255.255.0 on your PC
- Hold the button for 30 seconds (even if the light turns red at 20)
- Hook up a console cable and see what messages are displaying on the AP
- Did you rename the image file to c1130-k9w7-tar.default? It must be that name exactly.
jordan01060 Tue, 11/10/2009 - 05:15
Mr. Barrett,
Thanks so much for your help. I'm an idiot. I connected a console cable and watched the scroll. I watched it fail to open tftp://255.255.255.255/{file} and the light bulb went on...
So I turned off the firewall on the laptop (!!!) and everything appears to be working now.
Thanks again for slapping the stupid out of me...
-Jordan
Robert.N.Barrett_2 Tue, 11/10/2009 - 06:10
Any time. Just share the love and give someone else a slap when they need it ;)
Thanks for the points...
Rob Huffman Tue, 11/10/2009 - 06:18
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hey Robert,
Nice catch here! +5 points for this good work.
Cheers!
Rob
jordan01060 Tue, 11/10/2009 - 06:30
I'm trying to figure out how to mark your message as having solved my problem but can't find the option. Am I missing something else obvious?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
