Interface ATM0/3 regained cell
dtran
Level 6
Level 6
Hello all,
I have a 3725 router running IOS version 12.4(15)T9 with 2 VWIC-2MFT-T1 cards connecting to 4 Point-to-Point T1 circuits and configured as a 6MB bundle. I've noticing some packet drops under the ATM/IMA interface and I suspect that the packet drops could be related to the errors that I am seeing in the router logs. I am seeing these errors.
Nov 9 08:34:16.871: %ATM_AIM-5-CELL_ALARM_DOWN: Interface ATM0/3 regained cell
delineation.
Any ideas what could be causing these errors ? and how to go about fixing it ?
thanks in advance !!!
Danny
19 Replies 19
paolo bevilacqua
Please send "show controllers T1".
Hello Paolo !!! thank you very much for responding !!! Please attachment for show controller t1 outputs.
Danny
I think you should have clock source line, not internal.
Then if that's not enough, network-clock-select 1 t1 0/0
Hello Paulo !! Thank you very much for your quick response !!!
These are Point-to-Point T1 circuits, so I have one end sets to Line and other end sets Internal. Service provider does not provide clocking.
Here is what I currently have configured for network clock. Please let me know if I am missing something !!!
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate aim 0
Should I remove "network-clock-participate wic" command and add " network-clock-select 1 t1 0/0" command for each T1 ?
Thanks again !!!!
Danny
How do you know they don't provide clocking ? Sometime they say that, then it turns out that ain't true.
In any case I'd like to see show controllers T1 on the other end before you do anything.
Note with point-to-point T1 you will have better circuit circuit utilization using MLPPP, not ATM/IMA (hideous cell tax overhead).
Hello Paolo,
On the other end I am using an NM-ATM-4T1 module, there is no controllers. Is there an equivalent command for NM-ATM-4T1 ?
Thanks !!!
Danny
Try:
clock source line on both ends, on ISR also network-clock-select 1 T1 (circuit of your choice).
Let us know!
Hello Paolo,
I thought if the clock source is set to Line on one end then the other end must set to Internal for Point-to-Point T1 circuits or the circuit won't come up.
I currently have network clock configured as follow:
Do I remove "network-clock-participate wic" then add "network-clock-select 1 T1" command for each T1 ? and Will it affect production ?
Thanks Paolo !!! I very much appreciate your help !!!
Danny
Circuits will come up but if no good clock from it, you will have more errors.
With line clock, always leave -participate, add -select with one more circuits. These will need to have different priorities.
Hello Paolo,
I don't quite follow you.
You wrote "With line clock, always leave -participate, add -select with one more circuits. These will need to have different priorities."
Could you please explain in more details ? Basically I have 4 Point-to-Point T1 circuits with clock source configured as Line on side and the other side configured as Internal. Could you tell me how the network clock should be configure for each side ?
Thank you very much !!!
Danny
No problem, but it's the same that I've told you already:
Even if you have been told that circuit provides no clock, that is kind of unlikely, especially for long spans.
So my recommendation would be to try clock source line under each controller, and configure network-clock-select 1 T1 for one of them.
Currently I have the clock source set to Line on one side of the circuit. You want me to configure the other side of the circuit to Line as well then configure the Network-clock-select for that one T1 circuit correct ? and Can I do this live during production hours ?
Thanks Paolo !!!
Danny
Yes. You can do that at any time.
Hello Paolo,
Can you enable Network-clock-participate and Network-clock-select for MPLS T1s as well ? or this option is only for P-t-P T1 circuits ? or when do you enable this option ?
Danny
