Database Tuning / Query Optimization
Nov 9th, 2009
I'm trying to tune my MARS 110.
After clicking "Calculate Cardinality", 4 columns are recommended for indexing. When I select an item and click "Create Index" an error pops up saying "Can not create index before calculating cardinality at least once". I've Calculated Cardinality again but still can not create an index.
Has anyone else experienced this problem?
Bruno
dustinsuko Fri, 11/13/2009 - 09:15
I have the same problem. I'm running a MARS 110R...to date know one has been able to give me an answer regarding this either.
BRUNO WOLLMANN Mon, 11/16/2009 - 06:05
Turned out to be a browser version issue. I was getting the error when using IE8. Once I switched to IE7, everything worked fine.
MarcusWise Fri, 12/04/2009 - 07:49
I was experiencing this problem as well. After reading this, I went and tried to
schedule an index using Firefox (3.5.5) and was successful. I also tried setting the browser mode to IE7 inside of IE8 using the F12 trick, but this yielded the same results as IE8. Nonetheless, it does appear to be a browser issue.
r.koike Fri, 04/16/2010 - 11:58
I´m using CISCO MARS 50 and has the same issue with Google Chrome.
Is there any way to solve the problem without installing IE7?
GrumpyBear Wed, 06/02/2010 - 12:13
If it supports IE8 then has a bug been noted as the original poster and others (myself included) have verified that an error is always returned when trying to create indicies?
Scott Fringer Thu, 06/03/2010 - 04:29
  • Cisco Employee,
Initial support was implemented in CS-MARS release 6.0.4 as noted in the resolved caveats of the 6.0.4 release notes:
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/release/notes/rnote604.html
Internet Explorer 8 support was finalized in CS-MARS release 6.0.6.
This is noted in the correspoinding release notes:
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/release/notes/rnote606.html
Internet Explorer 8 Support—MARS  supports Microsoft Internet Explorer 8 without requiring compatibility  mode. Due to the nature of security revisions in Internet Explorer, you  may find that you must authenticate more frequently to the MARS  appliance.
Scott
