ASA5505 Trunk Problem
Nov 9th, 2009
Hello togehther,
I have a probem here with my ASA 5505.
ASA5505 + Security Plus Licnese.
I want to use the ASA Firewall to secure my WLAN. All my AP will be connect to the ASA and the ASA with my Router.
To do that i need to configure a Trunk port as Uplink to the Router(3560)
I configured a Trunk Port on the Router and on the ASA.
But i can not ping the ASA or connect with the ASDM.
I looks like that the Router dont know her.
With a "Show Inter Status" i see that the Port is connected with auto 100 full but the is no communication possible.
Iam not a Network Specialist so i need some help from you who have more experiance than me.
I Added the Config from my ASA.
Thanks a LOT if somebody can help me with that.
Matthias
francisco_1 Tue, 11/10/2009 - 03:37
  • Gold, 750 points or more
try
On ASA
interface Ethernet0/0
no nameif
security-level 100
no ip address
interface Ethernet0/0.1
description Subnet1
nameif vlan1
security-level 100
ip address 192.168.x.x 255.255.255.0
interface Ethernet0/0.2
description Subnet2
nameif vlan2
security-level 100
make sure you have you also have the vlans on the 3560 with ip address under SVI.
On 3560
setup trunk for vlan 1 & 4 on 3560 towards ASA.
int vlan 1
int vlan4
Hope that helps...
matthiasj Tue, 11/10/2009 - 21:37
Thanks for your answer!!!
But when iam running the Firewall on Transparten i do not need IP Adresses or?
I mean just the Mgnt. Adress.
On my Switch with Layer 3 there is a Trunk of course.
interface GigabitEthernet0/15
switchport mode trunk
And the Vlans are also configured.
Its still not working. I tried so many thing already. Maybe someone can give me an onther Idea to Fix that.
Thanks....
billyhall Wed, 11/11/2009 - 15:22
How did you produce the sub interface for your 5505 in your reply to the earlier issue. I understand that the 5505 will not allow creation of subinterfaces
