LAN Users Cannot able to connect VPN Through Cisco 1841
Nov 9th, 2009
I am using Cisco 1841 for my internet router.configuration as follows,my inside users cannot able to connect VPN Server( outside world server).i am trying to connect windows Xp VPN Client.wil genrate error No 721.Please help me to solve this issue
sh run
Building configuration...
Current configuration : 1530 bytes
version 12.4
ip dhcp excluded-address x.x.x.y
ip dhcp pool rusan
network x.x.x.x 255.255.255.248
default-router x.x.x.y
dns-server y.y.y.y z.z.z.z
lease 365
interface FastEthernet0/0
ip address b.b.b.b 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.0 secondary
ip address z.z.z.z 255.255.255.248
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 b.b.b.c
ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0/0 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
end
Thanks in advance
S.Mohan
Laurent Aubert Tue, 11/10/2009 - 20:51
  • Cisco Employee,
I assume your internal users are part of the x.x.x.x public subnet right ?
First check your routing is working (ping the users from the VPN Server and vice-versa)
If routing is fine (means your 1841 is not the root cause), checks the logs on your VPN server to troubleshoot the IKE negotiation.
Laurent.
