BGP route received twice - Whats the reason?
Answered Question
Nov 9th, 2009
  • Bronze, 100 points or more
Hi.. what puzzles me about the following output is that the same route is being received from the same upstream router (172.17.251.10) twice. How is that possible. I thought the upstream router would send only it's best one.
Router3#show ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 129
Paths: (3 available, best #1, table Default-IP-Routing-Table)
Advertised to update-groups:
1 2 5
65000 64512
172.17.251.10 from 172.17.251.10 (192.168.254.254)
Origin IGP, localpref 150, valid, external, best
Community: 65000:150
65000 64512, (received-only)
Origin IGP, localpref 100, valid, external
65000 64512, (received & used)
172.17.251.1 from 172.17.251.1 (192.168.32.254)
Origin IGP, metric 0, localpref 150, valid, internal
Correct Answer by adamclarkuk_2 about 7 years 6 months ago
It is soft-reconfiguration inbound at work here as Peter is suggestiing. This feature shows routes pre filtering / manipulation which is why the received only route has the default local pref value of 100 (pre route-map) and 150 (post route-map).
Check for the soft-reconfiguration inbound command attched to the neighbor statement under your BGP config.
Correct Answer by Peter Paluch about 7 years 6 months ago
Are you possibly using the soft-reconfiguration inbound feature on your router?
Best regards,
Peter
Overall Rating: 5 (3 ratings)
kozorezdi Mon, 11/09/2009 - 23:10
hi! it is a normal situation when you can see both prefexes: received-only and modified(in your case - localpref 150).
c.captari Mon, 11/09/2009 - 23:25
I would've thought that the upstream router 172.17.251.10 should send only the best route. Not 2 routes:
65000 64512
Note that this is an EBGP connection to 172.17.251.10 . And local pref is being set on my router. The reason why local pref is 150 on only one is that the route-map terminates as soon as it has a match. That's why the second time the route remains with local pref 100
kozorezdi Tue, 11/10/2009 - 03:07
hi!
no neighbor 172.17.251.10 route-map in
clear ip bgp 172.17.251.10 soft in
as result you will get the only one prefix from 172.17.251.10 by command: sh ip bgp 0.0.0.0 you can check it on GNS3 as well.
Correct Answer
Peter Paluch Tue, 11/10/2009 - 08:13
  • Cisco Employee,
Best regards,
Peter
Correct Answer
adamclarkuk_2 Tue, 11/10/2009 - 10:22
  • Silver, 250 points or more
Peter Paluch Tue, 11/10/2009 - 14:24
  • Cisco Employee,
Adam, thank you very much for confirming my suspicion.
Regarding the soft-reconfiguration, I find myself amazed at how many people are actually using this obsolete workaround years after all solid BGP implementations have started using the route refresh capability that is much more effective with respect to router resources, especially the memory.
There have been talks regarding the soft-reconfiguration and route refresh on these forums. I suggest reading, for example, this one:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cd44d1c/4#selected_message
You will need to copy the entire URL and paste it into your browser as the automatically generated hyperlink here does not contain the entire URL and is thus invalid.
Best regards,
Peter
