Restricting Access to Group
joe.marcelo9
Hello
I have ACS 4.0 authentication through external database Windows Active Directory. I want only support group created on ACS to have access rights to AAA client [Routers,Firewall,Switches] for telnet & SSH all members of other group should be denied.
Groups are created.
AAA members are added to ACS
but restricting to specific group not working
darpotter
Level 5
Level 5
Assuming you've confirmed that T+ authentications are actually been sent to your ACS, then it should be just a case of adding Windows group mappings:
Support -> ACS Support Group
Default -> NO ACCESS
Group mapping is applied after AD authentication, so even if correct credentials are supplied the user will be mapped to NO ACCESS (ie rejected) if they are not a member of the correct AD group.
