Idle Display for CCM7
Answered Question
Nov 9th, 2009
I need to configure the Idle Display for CCM 7. and to configure it I should put XML file in a web server and point the URL Idle field in System > Enterprise Parameters to the web server.
Can I use the CCM as WEB server?? If No can use Unity??
Correct Answer by Jaime Valencia about 7 years 5 months ago
You CANNOT load anything to CCM into the tomcat folders, you DO NEED a separate web server to host the files
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
JustForVoice_2 Wed, 11/11/2009 - 04:08
I saw this document before, I think we need a web server for this not the CCM.
I need to upload the xml file to CCM not to web server.
Correct Answer
Jaime Valencia Wed, 11/11/2009 - 07:03
  • Cisco Employee,
  • Hall of Fame,
    2011
java
