ipccx installation related queries
hi,
I am currently studying installation and administration guide of ipccx.
1)During installation it asks for AXL user id and password. what will be the AXL user id.. do i have to configure it on application user (in usermanagement window) or its just the userid and password of ccm.
2)to display the second call manager node on ccx i read follwing in adminstration guide.
"When connected to a Unified CM cluster, the Unified CM Configuration page in
the Unified CCX Administration GUI only displays the IP address of one node.
However, in a two-node cluster, it should show the IP addresses of both the
publisher and subscriber nodes. To display both IP addresses, you must configure the Domain Name Server (DNS) suffix information (for the required nodes in the cluster) in the server in which Unified CCX is installed."how can i get the dns suffix information..is it the hostnames of ccm1 and ccm2 or what ??
Naresh
Overall Rating: 4 (1 ratings)
Jonathan Schulenberg Tue, 11/10/2009 - 16:48
  • Cisco Designated VIP,
    2017 IP Telephony
1) You need to create an Application User on UCM with super user rights and provide those credentials here.
2) I haven't seen this before. You will see each node that is running the CTI Manager service during initial configuration and can add up to two I believe (as long as they are on the same campus LAN as CCX). Whatever node has the most phones/gateways relavent to your contact center is likely the best first choice.
The same goes for the AXL providers but always list the publisher IP address first.
Jonathan Schulenberg Mon, 11/16/2009 - 16:26
    2017 IP Telephony
1) I wouldn't recommend it. Separate Application User accounts don't cost you anything and provide good isolation in case someone gets the idea to change the default administrator account password.
2) I don't understand what this is talking about at the page you referenced. I am looking at a CCX 7.0(1)SR4 installation right now and there are two AXL, Telephony Subsystem, and RmCm Subsystem IP addresses in all three. These are the addresses for the appropriate UCM servers.
