Ap1100, roming problem with non Cisco usb-client cards
Nov 10th, 2009
we have an campus installation with a lot of ap1100 standalong AP's ( 5 years old ) .
- and AIr-PCM4800/350 Client adapter
- on Windows Laptops.
Now we have to replace the old Laptop with newer. But ther is only USB Interface availible. And cisco has no adapter.
With Linksys WUSB600 Adapter we have somtimes
roming problem (and also Ping missing )5 to 6 seconds long.
Who can help.
jeff.kish Tue, 11/10/2009 - 04:59
I hate to say it, but I've seen this before with LinkSys adapters. Consumer-grade adapters just aren't as high of quality as enterprise cards like Cisco adapters.
The best thing you can do is perform a site survey, setting all APs to about 30mW. I believe that's as strong as the LinkSys cards broadcast. You might just have coverage holes that the Cisco cards were able to overcome.
I hope that helps,
Jeff
jeff.kish Tue, 11/10/2009 - 10:50
I don't know of any enterprise-grade USB cards. It's unfortunate that Cisco doesn't make USB cards.
I'll also add that if you're going to use USB clients, you might as well use the internal wireless cards in the laptops since they're likely on the same level of quality. Heck, the internal cards can sometimes be better, as some laptops have antennas that wrap around the screens, boosting their signal.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
