E1 flap
Nov 10th, 2009
Dear all,
E1 flap during the past last 3 weeks, and you recommended me this command:
network-clock-select 1 E1 0/1/0
It looks good as this command made 0 Slip Secs & 0 Errored Sec.
But, E1 still flap again, if i can increase the priority again from 1 to 8 or it will do nothing and if so, no other recommendation can be done from my side.
Ahmed Yassin Wed, 11/11/2009 - 00:43
E1 cable is 2 pairs and made from 3 years ago from starting of E1 service.
It working but suddenly down then up again at the same moment. So, any call will be terminated.
I am talking about the command shown aboe, if i can increase the priority or no.
Paolo Bevilacqua Wed, 11/11/2009 - 12:24
I was asking: how many flaps do you have each day ?
Changing priority doesn't make a difference.
sebastiandm Thu, 11/12/2009 - 03:15
Do a clear counters and then sh int serial 0/1/0:15 after about an hour...post the results.
Paolo Bevilacqua Fri, 11/13/2009 - 06:44
Open a ticket with telco.
They will say that everything is OK, at which point you will have to ask for diagnostic equipment be put inline.
