Snmpwalk
Nov 10th, 2009
I'm trying to retrieve information about my rservers, associated ip-addresses and current state. I'm using the following syntax:
snmpwalk -c [email protected]-TEST 10.10.5.36
MED-TEST is the user context and 10.10.5.36 is the ip of the admin-context, as I've understood, that all snmp-interaction has to be done via the Admin-context. I get tons of output back, but nothing about rservers and associated info.
I'm most likely doing something wrong, but I can't seem to find out what.
/Ulrich
UHansen1976 Tue, 11/10/2009 - 04:41
Hi Gilles,
Thanks.
But when I do an snmpwalk using the following string snmpwalk -c [email protected]-TEST 10.10.5.36 .1.3.6.1.4.1.9.9.470.1.1.1.1.1, I get the msg 'no MIB objects contained under subtree'.
I'm still confused as to whether the snmpwalk actually tries to gather information from the usercontext and not the admin-context.
Also, at the object-navigator url you provided me, the permission says 'not accessible'. Am I to understand, that I cannot retrieve this information via snmp.
/Ulrich
