SRST with Connection 7, getting unknown number
Nov 10th, 2009
Hi, my CUCM,Connection and MGCP GW are at lan environment, don't have any PSTN/PRI connections at GW. Phones are getting registered with SRST router when shutting down CUCM switchport, but don't getting voicemail access while pressing message button. Have issued 'voicemail xxxx' at 'call-manager-fallback' section, any idea?
The configuration is here:
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7940 1
limit-dn CIPC 1
ip source-address 10.234.155.40 port 2000
max-ephones 3
max-dn 6 dual-line preference 1
voicemail 9000
call-forward pattern 4...
time-format 24
date-format dd-mm-yy
I have also tried with the following commands:
vm-integration
pattern direct * CGN
But getting unknown number tone while pressing the phone message button. Any idea?
