set an ip unnumbered from radius
Nov 10th, 2009
Hi all,
I was reading a lot documentation and testing a lot of scenarios but i can not set template configuration from RADIUS…
This it my configuration,
aaa new-model
aaa authentication login admin local
aaa authentication ppp default local group radius
aaa authorization template
aaa authorization network default group radius local
aaa accounting delay-start
aaa accounting update newinfo
aaa accounting network default start-stop group radius
bba-group pppoe pruebavrf
virtual-template 33
sessions per-mac limit 48
sessions per-vlan limit 1400
interface Loopback10
ip address 192.168.44.1 255.255.255.0
interface FastEthernet0/0.8
description PRUEBAS
encapsulation dot1Q 8
pppoe enable group pruebavrf
interface Virtual-Template33
no ip address
no ip redirects
no ip unreachables
ip mtu 1480
ip tcp adjust-mss 1400
peer default ip address pool pool_local
ppp authentication pap chap
radius-server attribute 44 extend-with-addr
radius-server attribute 8 include-in-access-req
radius-server attribute nas-port format d
radius-server configure-nas
radius-server host X.X.X.X auth-port 1812 acct-port 1813 key xxxx
radius-server retransmit 2
radius-server timeout 6
radius-server vsa send accounting
radius-server vsa send authentication
ip local pool pool_local x.x.x.x
And this is RADIUS configuration
[email protected] Auth-Type := local, User-Password == "xxxx"
Service-Type = Framed-User,
cisco-avpair += "template:ip-unnumbered=Loopback 10",
Framed-Protocol = PPP
I think that with this configuration virtual-access would be take the ip of Loopback 10 as unnumbered but doesn't work.
Router#sh int Vi2.1
Virtual-Access2.1 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1492 bytes, BW 100000 Kbit/sec, DLY 100000 usec,
Encapsulation PPP, LCP Open
PPPoE vaccess, cloned from Virtual-Template33
Vaccess status 0x0
Keepalive set (10 sec)
128 packets input, 1803 bytes
128 packets output, 1799 bytes
This is the RADIUS debug,
.Nov 10 12:38:42: RADIUS(000E4E19): Send Access-Request to x.x.x.x:1812 id 1645/79, len 135
.Nov 10 12:38:42: RADIUS: authenticator 3C 22 8C 1E AE 21 20 82 - B9 58 57 E3 16 6D C9 8B
.Nov 10 12:38:42: RADIUS: Vendor, Cisco [26] 41
.Nov 10 12:38:42: RADIUS: Cisco AVpair [1] 35 "client-mac-address=xxxx"
.Nov 10 12:38:42: RADIUS: Framed-Protocol [7] 6 PPP [1]
.Nov 10 12:38:42: RADIUS: User-Name [1] 17 "[email protected]"
.Nov 10 12:38:42: RADIUS: User-Password [2] 18 *
.Nov 10 12:38:42: RADIUS: NAS-Port-Type [61] 6 Ethernet [15]
.Nov 10 12:38:42: RADIUS: NAS-Port [5] 6 8
.Nov 10 12:38:42: RADIUS: NAS-Port-Id [87] 9 "0/0/0/8"
.Nov 10 12:38:42: RADIUS: Service-Type [6] 6 Framed [2]
.Nov 10 12:38:42: RADIUS: NAS-IP-Address [4] 6 x.x.x.x
.Nov 10 12:38:42: RADIUS: Received from id 1645/79 x.x.x.x:1812, Access-Accept, len 74
.Nov 10 12:38:42: RADIUS: authenticator E5 D8 63 D4 D5 EE EC C8 - F7 BB 4A B9 6A C8 60 F6
.Nov 10 12:38:42: RADIUS: Vendor, Cisco [26] 42
.Nov 10 12:38:42: RADIUS: Cisco AVpair [1] 36 "template:ip-unnumbered=Loopback 10"
.Nov 10 12:38:42: RADIUS(000E4E19): Received from id 1645/79
Somebody can help me?
Thank you in advance.
