CUCM 5.3 rebooted automatically
Nov 10th, 2009
My SUB of version 5.3b(c) rebooted automatically. I don't know the reason. Can anyone help me how to check RCA for the reboot? Is there any log saved somewhere on CUCM so that I can capture it and analyze for the root caused.
Ram
Jaime Valencia Tue, 11/10/2009 - 08:37
  • Cisco Employee,
  • Hall of Fame,
    2011
You would need to look at the app log and SDI traces in order to determine root cause, i would suggest you reach TAC
BTW, if you don't have the info at the required level to log the errors there is now way to determine root cause.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ramnivaslal Sat, 11/14/2009 - 07:35
Thanks for reply. I will check SDI trace and let you know.
Thanks & Regards,
Ram
