BPDUguard does not shut down port when bridge connected
Nov 10th, 2009
I have a port configured as follows:-
test01#sh run int fa0/10
Building configuration...
Current configuration : 217 bytes
interface FastEthernet0/10
description <user ports>
switchport access vlan 10
switchport mode access
switchport nonegotiate
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
It is still participating in STP
test01#sh spanning-tree vlan 10
Spanning tree enabled protocol ieee
Root ID Priority 4106
Address 001f.6dcf.3000
Cost 3004
Port 25 (GigabitEthernet0/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 49162 (priority 49152 sys-id-ext 10)
Address 0025.b40c.3880
Aging Time 300
Uplinkfast enabled
Interface Role Sts Cost Prio.Nbr Type
Fa0/10 Desg FWD 3019 128.10 Edge P2p
Gi0/1 Root FWD 3004 128.25 P2p
test01# sh cdp ne
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
Switch Fas 0/10 170 S I WS-C2960- Fas 0/4
If I turn snmp trap link-status on then it works as expected.
Bug search does not come back with anything relevant
I am running WS-C2960-24TC-L 12.2(35)SE5
Giuseppe Larosa Tue, 11/10/2009 - 10:21
Hello Steven,
have you enabled BPDU guard before connecting the other switch of after ?
because the port is Designated the other switch doesn't talk on the link.
to test BPDU guard on other switch you need to cause it to send a BPDU for example by changing state of a port that is not portfast so that it has to send a TCN BPDU upstream towards root bridge.
I had the same problem first time I tested BPDU guard.
Hope to help
sprosons Wed, 11/11/2009 - 01:35
thanks for the reply Giuseppe
I tried it both ways and it still didn't work. However, I have since upgraded to 12.2.44SE6
and it works fine now. Must be a bug.
Giuseppe Larosa Wed, 11/11/2009 - 03:24
Hello Steven,
if adding the switch after having enabled bpdu guard still no reaction well it is a SW bug.
I'm glad that you solved with an IOS upgrade.
Hope to help
Francois Tallet Wed, 11/11/2009 - 07:40
Could be a timing issue too. F0/10 is designated. That means typically that the bridge on the remote end of f0/10 has a root/alternate/backup role. In those role, no bpdu is sent. So it might well be that f0/10 never received a bpdu.
If you saw some bpdu received on f0/10 in "show spanning-tree detail", then it would obviously be a bug.
