Port Description-Filter in CM port Vlan ASSIGMENT
Nov 10th, 2009
Hello to every body
I'm working with CiscoWorks LMS 3.0.1 and in the specific my problem is concerning on CM (Ver. 5.0.2), because in the old version I was using (4.0.10) of campus manager you could do a search starting witch the port description of the Switch port.So!this old version had a field called -Port Description- in the VLAN ASSIGMENT utility and it was useful of doing a research using the description name/number of the SwitchPort. Do anybody know how I can do the same with this new version considering this version doesn't have -Port Description- filter in VLAN ASSIGMENT utility ?
Thanks so much in advance
yjdabear Tue, 11/10/2009 - 07:40
  • Gold, 750 points or more
LMS 3.1 (CM 5.1.3) here. I see a choice of "Port Description" in the Filter dropdown list, at CM - Configuration - VLAN Port Assignment. So it doesn't seem the feature was intentionally dropped, if at all.
