RME 4.0.6 Device Package update failure
Nov 10th, 2009
i have downloaded a lot of new device packages for the RME 4.0.6. If i install this packages i get the following error message.
Installation failed for product [Resource Manager Essentials] with message : com.cisco.nm.xms.psu.packagemgmt.InstallerException: Repository in use.
Another Package Support Updater client session may be modifying device support.
I searched for the psu.lock file but i couldn't find this file. How can i fix this without reinstalling the lms?
André
Joe Clarke Tue, 11/10/2009 - 08:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Check NMSROOT/www/classpath/com/cisco/nm/xms/psu for a lock file. If it exists, delete it.
aeggers Tue, 11/10/2009 - 08:59
hi,
there is no lock file. i see that the psu.log is growing and growing, but after some minutes it starts again from 0 kbytes also if i stop the lms daemons ??
andre
Joe Clarke Tue, 11/10/2009 - 09:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That error can only mean a lock file exists. The only two lock files will be NMSROOT/Psu.Lock or NMSROOT/www/classpath/com/cisco/nm/xms/psu/psu-installer.lock. Post the full psu.log.
aeggers Tue, 11/10/2009 - 23:04
i have attached the psu.log file. There is no .lock file, i've checked this again. I tried again to update the device packages
After 1 hour i stopped the update.( normaly an update take max. 10 minutes. During the device package update i could see the the psu.log file was going into a loop. It starts at 0 kbytes -> growing to nearly 950kbytes and than it starts again at 0 kbytes
Andre
Joe Clarke Tue, 11/10/2009 - 23:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Your package repository is corrupt. It needs to be recovered. There is a procedure available by contacting TAC. They will send you a package bundle and steps to recover the repository.
aeggers Tue, 11/10/2009 - 23:11
Hi Joe,
thank you very much. I will open a service request.
Have a nice day.
André
